installing valves for n.g pipelines, before or after hyd. test?
Dear friends,
I heard from some engineers, that, conducting hyd. static test on pipeline; must be before installing secion valve rooms,especially for natural gas and crude oil pipelines, to keep valves safely from dust and impurities. is that true or what
thank you in advance.
RE: installing valves for n.g pipelines, before or after hyd. test?
There is a lot of rubbish talked about what you must and must not do during hydrotestingg but most of this is simply custom and practice of the individual or company. The only thing you need to do is follow the code requirements.
