Patran - Parametric modeling
Hi everybody,
I have problem to update the model configuration (my_config1.dat) using the parametric modeling in Patran. When the session file is played I get this message: "The Parametric Modeling Configuration File [ my_config_1.dat ] does not exist. Variables will remain at their base value", but the .dat file with the new model configuration exist in the same folder.
Thank you in advance..
