Chapter 11.2.4 NGL/LPG Example 23/5 - T23/6,RDtf < lower boundary on Page 46
Nubee here, I am in the process of coding the above chapter and I am having an issue with one example (that I know of).
In all examples where RDtf for Fluid1 (Lower Fluid) is a positive number, the RDtf Fluid1 value is used later as the "Lower Boundary RDtf, low"
Why is this Example 23/5 Para T23/6 an exception to that observation?
If you know of a better forum for this query please advise.
Thank you.
Thank you.
RE: Chapter 11.2.4 NGL/LPG Example 23/5 - T23/6,RDtf < lower boundary on Page 46
Aside from that, wouldn't giving the full title and author of the book might be of some use?
TTFN
Of course I can. I can do anything. I can do absolutely anything. I'm an expert!
