API 650 12th Ed. Addendum 1 update to S.3.6.6
Addendum 1, which came out this September, updated section S.3.6.6 so that the old M.6 requirement to modify according to temperature the yield stress used in calculating the unstiffened shell height for stainless steels is no longer required. Section X.3.7.2 (duplex steels) was updated to include modifying the Modulus of Elasticity, but left in the requirement to modify yield stress. Did the API make a mistake in removing the M.6 requirement from S.3.6.6? It doesn't seem right to keep it for carbon and duplex steels, but take it out for stainless.
RE: API 650 12th Ed. Addendum 1 update to S.3.6.6
The next errata apparently came out earlier this month. However, it doesn't address this section. Also, they were kind enough to not include the replacement pages as they have in the past. I guess I'll have to modify our copy with a red pen.
http://www.techstreet.com/products/1888158
"This errata corrects editorial errors in the twelfth edition of API Standard 650.
Replace the following pages with the attached:"
The corrected pages are then in the errata and can be easily inserted into the base document. With the last Errata, there's no easy way to update it.
http://api.org/~/media/files/publications/addenda-...
