WPQ to AWS D1.1 material type range
If I qualify a welder using a36 a P1 G1 material to AWS D1.1 how many different types (range)of materials will the welder be qualified to weld?
Thank you,
Moe27
Thank you,
Moe27
RE: WPQ to AWS D1.1 material type range
ASME SEC X will allow a welder to weld from P1 to P11 if qualifying on P1 material, would welder be allowed to weld on P1 to P11 material if certified to AWS D1.1?
Thank you.
Best regards - Al
