Weather tight closing appliance For Modu
If the self elevating jack up drilling rig is following Modu code, the ventilators need to install weather tight closing appliance if the ventilators are less than 4.5 m above the main deck. We do have the shut off dampers to be able to close the compartment it serve at main deck. But I do believe that this is for the fire safety and can not be use as weather tight closing device. Yours valuable advices are much appreciated.
