Need help undestanding pumps
I am looking for a pump that can pump both liquid and gas . My current process is vacuum coating About 50 g of viscous fluid is dosed on a substrate 25g of which is coated and the rest is sucked by the vacuum into a baffled separater . I am thinking of replacing this system with a pump of piston type which can provide the vacuum pressure during the suction movemnet and discharge the gas and liquid present by the discharge motion. http://files.engineering.com/getfile.aspx?folder=b...
RE: Need help undestanding pumps
Som kind of ejector pump might do it if contamination with the motive fluid is OK?
