Upper temp limit sa36
RE: Upper temp limit sa36
What are you trying to prevent?
How much sag or movement or deflection (% yield under the stress load you anticipate) can you tolerate?
How long will the loads at high temperatures last?
If you need a maximum service temperature reference, I would suggest ASME Boiler and Pressure Vessel Code, Section II, Part D, Table 1A
900 deg F for SA 36 plate material.
