Calculate Gauge Pressure On Suction Side of Pump
I am trying to determine the correct method for calculating the gauge pressure on a pressure transducer that will be installed on the suction side of a pump. This transducer will be used to set the water level in a tank that will be feeding the pump. There are several lines entering into the suction header of the pump, so I will have some friction and minor losses. I am trying to wrap my head around how to calculate what the pressure will be when the pump is running. I can easily calculate the static head (~20 feet). The suction losses at the design flow will be about 10 feet. I can easily determine what the gauge pressure will be when the pump is not running, but I can't figure out how to calculate the effect that the running pump will have on the pressure in the suction header. I know it shouldn't be too complicated to determine, but I can't seem to find any information in my textbooks that will guide me in the right direction.
RE: Calculate Gauge Pressure On Suction Side of Pump
Good luck,
Latexman
Technically, the glass is always full - 1/2 air and 1/2 water.
http://www.engineeringtoolbox.com/darcy-weisbach-e...
or the Equivalent Pipe Length Method:
http://www.engineeringtoolbox.com/equivalent-pipe-...
to calculate the pressure loss in the pipe.
The pressure setting for the transducer will be field set so you do not have to calculate a precise number. You should be able to either set the pressure in the field on the instrument, or set the pressure within the SCADA control system.
Good luck,
Latexman
It all seems an odd way to control a tank level to any degree of accuracy?
a sketch would be good.
