How to access existing steel without original loads?
On a current project we’re slightly increasing the point loads at a few locations on the existing steel (ordinary concentrically braced frame) at a few locations inside a power plant. I would normally use the IBC provision 3403.3 stating existing members carrying vertical load can accommodate a load increase of 5% without needed evaluation. Because the horizontal steel does not support any slabs, gratings, etc. the load increase on the point loads on the beams is in the realm of 10% negating the use of this provision. Without having the existing loads on these beams (the client doesn’t have them), how can I evaluate the existing steel for the increased loads? Intuitively I know that adding 5kips to a W21x211 with a 30ft span will likely be acceptable but how can I prove this without having the original calcs that determined the beam sizes?
RE: How to access existing steel without original loads?
Then with your added load you can evaluate the percent change in the various effects (moment, shear, etc.).
Mike McCann, PE, SE (WA)
Regarding the 5%, I understand the codes to apply it to forces in elements rather than loads on the member.
Additionally I've worked on remodel/retrofits where our determination of capacity based upon measured section properties led to a conclusion that the structure was not properly supporting the existing load, not to mention a 5% increase.
Msquared48: I have drawings for the plant, just no loads. These beams aren't supporting any vertical load. Would FERC perscribe loads to use that are in addition to ASCE 7?
Triangled: Are you recommending that I check the beams can take the load increase and assume there is no existing loads other than self weight?
www.SlideRuleEra.net
www.VacuumTubeEra.net
They could. Power plants are notorious for moving heavy equipment.
If these beams support no vertical load though, are they part of a moment frame?
"Triangled: Are you recommending that I check the beams can take the load increase and assume there is no existing loads other than self weight?"
No, if I understand what you're thinking in your question to me, I am definitely not recommending that. What I am suggesting though is that the 5% thingy maybe is not the way to approach this calculation. You mention you have the drawings, which i would suppose, have the member sizes and connections. I'd recommend that you determine what the new loading combination will be and check the structure for that combination. This eliminates errors associated with the observations of others here such as Msquared48 "Power plants are notorious for moving heavy equipment." If multiple engineers sequentially apply the 5% thingy (
In the original design, it was common, but not universal, to leave a large margin for additional loads, this may work for you.
Michael.
"Science adjusts its views based on what's observed. Faith is the denial of observation so that belief can be preserved." ~ Tim Minchin
Triangled & SlideRuleEra: I will perform a site visit to ensure the pipe supports (some of which will be increasing) shown in the drawings and photos are the only loads on the beam.
Msquared48 & Paddingtongreen: The structure looks to be all braced frame not moment frame. The larger secondary horizontal members look to be sized mainly for resisting horizontal load as they are 30ft long and they support the external wall of the plant.
TLHS: I would enjoy and feel more confident performing a full analysis of the structure to determine the loads in the primary beam (supporting the pipe) and secondary beams (supporting the primary beam) but unfortunately time and budget don’t allow this.
I’ll confirm the strength and connections of the primary beam are acceptable for the load increase. Should the secondary beams that support the primary beam have no additional loads (additional pipe supports not shown in drawings or photos, moved heavy equipment. etc.) beyond those from the primary beam, then it appears the most prudent approach is to verify the additional load from the primary beam is below 5% of the secondary beam’s nominal capacity and then write off the load increases as acceptable.
