get right values in drop test simulation usinf abaqus
Hi all:
I'm trying to simulate a drop test of a structure from certain height. I entered all information needed for running the simulation. when I looked for the results in history, I found that the C.G. acceleration graph started from zero value. As the drop test is of free fall object type, it should start from -9.81 m/s^2 and continue constant up to the moment when the structure hits the ground. in the assembly I defined the mass at the C.G. of the assembly along with the mass moment of inertia. Also, I fixed the ground on which the structure impacts. I tried to define gravitational acceleration in y direction (negative= downward) but it increased the kinetic energy instead of decreasing it which violated the conversation of energy law.
Can anyone help with how to fix this problem.
Mofy
Mofy
