Error recovery - "Invalid attempt to load library"
I keep getting the error message "invalid attempt to load library" everytime I try to export a dwg file or even some other file formats like igs. Does anyone kno whow to resolve this issue?
Thanks.
RE: Error recovery - "Invalid attempt to load library"
I have NX9
Sounds like you have an install problem. Have you tried to uninstall NX and the reinstall it to see if this resolves the problem?
John R. Baker, P.E.
Product 'Evangelist'
Product Engineering Software
Siemens PLM Software Inc.
Digital Factory
Cypress, CA
Siemens PLM:
UG/NX Museum:
I'll look into it, thanks!
Hello guys
I'm not sure if this was resolved.
I'm having the same error on NX 9. I've done some research and tried a some suggestions but I keep getting the error.
NX version 9.0.3.4 running on windows 7.
I re-installed netframework (I tried both 4 and 4.5) and I did a repair on my NX 9 installation.
We have NX 9 in 3 machines, 2 of them are working fine. Just one (the one I usually use :S) gives me the error.
I appreciate any feedback.
Thanks!!!!
I don't know exactly what the issue was but the 2nd time I re-installed it, it worked.
Thanks for the answer, I did a clean installation again and it's working now.
Thanks again!
