SPAR, TRUSS SPAR AND TLP
I have simple problem about floating offshore platform type
I’m not clearly understand the different between “SPAR”, “TRUSS SPAR” and “TLP” (Tension leg Platform), from the shape, function, range depth of sea level, riser protection , and other.
Can someone explain the advantages and disadvantages for that three types?
Thank you for response and answer
Zachari Alamsyah
Zachari Alamsyah
