Editing drafting with paramertic model in V5-6R2013.
Hello!
Is there a way to make a formula for length of section cuts, the point where you take a detail view etc. in a drafting?
I have made a parametric 3d model using the design table and the goal is that when I change the parameters in a 3d model, place of a detail view and other stuff would scale automatically with the part after updating the drafting.
Can you for example make a relation between a length of a section cut and a dimension of a part?
