Problem with Portable LED Message Center (Ground Fault)
I'm having problems with a portable LED message center tripping a 20amp GFCI receptacle, but it never pulls more than 10.4 amps.
The problem lies in the inductive loads of the power supplies.
I've asked several experts, but to no avail. My question is, will some type of filter or UPS (Uninterruptible Power Supply) condition the load before it reaches the GFCI?
Read some of my conversations below....
Looking over the 2014 NEC, there's mention of LED drivers being grouped with other inductive loads such as ballasts, solid-state power supplies and transformers that deserve special consideration. I imagine some type of filter system(s) may help, but it's beyond my knowledge level on what kind, or the specifics on how to compute the filtering requirements... If you figure this all out, how about shooting me another email on the details... I believe you working in the future of all lighting.
Best regards,
Fred
Electrical Instructor
Contractors Institute
Best regards,
Fred
RE: Problem with Portable LED Message Center (Ground Fault)
If you put in a single (not duplex) that is dedicated to this gizmo, it probably does not need to be GFCI. You could make it a twist-lock for good measure.
