How to Identify the Curves & lines created by Expand in Drawing Views
Hi Folks,
Anyone Please give a solution to identify the curves & lines which are created using the "Expand" in drawing views.Since our customer suggested created using expand in views is a fake method of parametric.So need your help to sort out this issue ASAP
RE: How to Identify the Curves & lines created by Expand in Drawing Views
Cowski,
Need your feeback on the above post
What version of NX?
www.nxjournaling.com
Info -> Object
It will state "view dependent in . . . " the information window, maybe 12 lines from the top
Cowski,
We are using NX8.5
Do any legitimate modeling curves show up in the view?
If not, try starting the delete command, set the selection filter to curves, and window select around all the drafting views.
If there are modeling curves in the view you will need a better way to distinguish between the curves.
Its not working,If I filter lines/Curves & select the views,its Highlighting the Entire view edges but i wanna filter out the lines & curves which are created in the "Expand" mode.So please elaborate a solution for this
You can simply go into your model space and Hide everything in there then go to your drawing and see what lines are showing in the views.
Thanks very much Jerry! its easy to identify the lines & curves.Cowski thks a lot for your updates too.
