The Washer hardness vs the Nut or the Bolt hardness
What are the advantages or disadvantages due to using a washer with hardness higher than specified in a certain application
EX: using Washer with 410 HV10 (its Sp. Value : 250 to 380 HV10) with bolt 360 HV10 & nut 280 HV10 ( 1st Case )
or using washer 200 HV10 with the same bolt and nut ( 2nd Case )
RE: The Washer hardness vs the Nut or the Bolt hardness
generally washer are sacrifical ...
Since we can only see 3 dimensions and physicists tell us there are more than 3 dimensions, we can argue that paradise is in our midst, except we can't see it.
