Percent off Pump Curve
Is there a standard method for calculating the percent off a pump curve for pump which has degraded performance over time (wear rings, impeller wear, any other reason really)? The way I see it there are two possible methods but maybe there is additional methods I am unaware of. The two I can think of either is a constant flow or constant head method.
For example if you had pump which you measured to have a TDH of 100ft @ 100 GPM and the curve showed at a TDH of 100ft the flow should be 150GPM your percent loss based on flow would be 1- 100/150 or 33% loss. However the curve would also show at 100GPM the head should be 110ft so your loss based on head would be 1-100/110 or 9%.
Also is there a percentage off the pump curve you generally consider to be acceptable based on those two or other methods? Like is 5% considered reasonable based on measurement errors, just some losses from wear ect. What about 10% or more? Or does it just depend upon what the losses are causing process wise.
RE: Percent off Pump Curve
However strictly speaking- head is more technically correct. The reduction in head at constant flow is a function of pump wear. The reduction in flow is impacted by the system curve.
You can have two pumps with exactly the same level of wear- and they'll give the same reduction in head but different reductions in flow if they are on separate systems with different system curves
As a chem eng/metallurgist the first part of any answer I give starts with "It Depends"
If you determine the loss of flow for a pump operating in a system, then certainly, the system curve will play a role. But, if you relate everything back to the pump curve as percent of flow at a given (fixed) head, then the system curves is no longer relevant. By definition, the head is constant. You are simply comparing to flow values for the pump in new condition and in the degraded condition at a fixed value for head.
I track and report on the performance of two of our largest pumps. These are our coker jet water pumps. I report on the pump performance as percent of curve at rated flow. I take the flow and head of the pumps. I convert the head to the rated flow using the affinity laws. I compare the head at the rated flow to the head value from the original test curve for the pump at that same flow rate.
(Head today at 1000 gpm) / (Head on test curve at 1000 gpm) x 100 = percent of curve at rated flow.
Johnny Pellin
Anyone have any thoughts on percent off curve where you can be confident pulling and rebuilding the pump will improve performance. I currently have our operations group pushing to pull and rebuild a pump because "it isn't performing as good as it used to" but I haven't seen any data that backs that claim up at all and the pump is less than 5% off the curve. To me 5% seems like it could be from anything and you could pull the pump and find nothing and just waste time and money. Pressure gauges, flow measurement, changes in specific gravity, ect.
Thanks again for your previous thoughts and any more you have.
Please correct if I am wrong somewhere I am still very new to this.
Little inch: good point my question though is can you actually expect to return to the labeled curve after you rebuild the pump or should you always expect to be a little under in the real world.
Restrictions in the upstream or downstream system will not change your evaluation of pump performance as percent of curve. But, it will change the operators perception of how bad the pump is performing. And the louder the operators howl, the harder it will be for you to resist their push to overhaul the pump.
Johnny Pellin
A dead head test though shows the pump performing as expected- and you can see the delta between the theoretical and actual head increasing as you test higher flows- again with my measured NPSH marging remaining "ok".
Based on your second post it wasn't clear to me that you had put gauges on the pump suction/discharge. My comments refer to operations asking for a pump change out before any pressure/flow checks are done (including a dead head).
As per JJPellins posts- if you're after more specific help you're going to need to provide more specific information.
I would suggest that a percentage of the production lost is a more meaningful measure, irrespective of what the head or flow reduction is, ie current flow / design flow x 100 = reduction in production performance. Of course this is on the premise that the pump was operating at open discharge and not throttled in any way to reduce production output -- if operating with throttled discharge, reducing the restriction will / should return to the required output, again doesn't matter what pump reduction is in percentage as once the pump can no longer meet production requirements - either, time for maintenance or live with a reduced production output.
