Pattern Feature and increasing number
I have an old grip program that pattern symbol and increase the number like the below image
I need to replace it with standard function.
I tried to use pattern feature, but I can't find the way to increase the value in Text(2) to 1, 2, 3 ...
So I found a trick by adding an arc in the sketch and a perimeter constraint (perimeter_p90=1)
and text2=ug_askExpressionValueAsString( Perimeter_p90, "%g" )
It works well in tools expression
But the expression text2 is not updating in the pattern
Thanks in advance for any suggestion
Didier Psaltopoulos
http://www.psi-cad.com
RE: Pattern Feature and increasing number
Didier Psaltopoulos
Didier Psaltopoulos
Menu -> Tools -> Update -> Update for External Change
John R. Baker, P.E.
Product 'Evangelist'
Product Engineering Software
Siemens PLM Software Inc.
Digital Factory
Cypress, CA
Siemens PLM:
UG/NX Museum:
but it doesn't work.
Any idea for another method to do the job
Didier Psaltopoulos
I found the solution
But as John said I need tu use tools / update for external change
Didier Psaltopoulos
