proper phrase help - replumbed?
If I'm talking about a structural post that needs to be made plumb again, should I say it should be replumbed? Or is there a better phrase for that? I'm stuck on it for a report.
Please remember: we're not all guys!
RE: proper phrase help - replumbed?
cheers, KENAT. My ears too. Thanks.
"corrected" ? or the post was reinstalled (?) (or removed and installed ?) in a true vertical orientation.
If you say "re-plumbed", that implies that it was plumb originally. Do you know personally that that was the case?
If not, then say that the post needs to be made plumb.
I know... picky, picky. poke
Mike McCann, PE, SE (WA)
Mike, good point. I don't know for sure, so I'll go with the other ideas.
Reinstalled to its correct vertical situation.
Wouldn't that be "vertical orientation"?
Pretty well interchangeable however, I prefer situation over orientation
Adjusted to correct vertical position?
"Made vertical"?
Who even cares if it originally was vertical?
JHG
Given an addadictomy.
urgross: did you mean an uprising?
sit·u·a·tion
noun \ˌsi-chə-ˈwā-shən\
: all of the facts, conditions, and events that affect someone or something at a particular time and in a particular place
: an important or sudden problem
: a place or location
I don't think that means the same thing as orientation at all. An object has 6 degrees of freedom. Location fixes 3 of them, orientation fixes the other three.
Drawoh:
A lawyer...
The beauty of English - so many ways to say the same thing or just about the same thing.
Trued.
Fracophone for the loss! hahaha
I think you'll find that English is the only language for which there is even the need of a Thesaurus.
John R. Baker, P.E.
Product 'Evangelist'
Product Engineering Software
Siemens PLM Software Inc.
Digital Factory
Cypress, CA
Siemens PLM:
UG/NX Museum:
And that's why the pun is generally confined to English.
Yeah this
is really off base. You are, technically, correct - Most languages do not have a word for such a book, but rather call it a "Dictionary of synonyms and antonyms". For a quick example, here is the output for a simple french word, maison, or "house":
maison, s nom féminin singulier
1) appartement, demeure, domicile, foyer, gîte, habitation, home, logement, logis, pénates, toit
2) appartement, cabane, demeure, foyer, gourbi, hôtel, logement, logis, pénates, toit, villa
3) bercail, chez-soi, demeure, foyer, home, logis, toit
4) église, loge, sanctuaire, temple
5) entreprise, établissement, hôpital, manufacture, prison - Antonymes : subversion
6) artisanal
For a further discussion of this topic, particularly as it pertains to comparing English to other languages, including French, may I suggest the book 'The Mother Tongue - English And How It Got That Way', by Bill Bryson.
John R. Baker, P.E.
Digital Factory
Cypress, CA
Siemens PLM:
UG/NX Museum:
Haha... I absolutely love the entry for the Antonym!
In the dictionary under 'iterative', it says, "See iterative".
John R. Baker, P.E.
Digital Factory
Cypress, CA
Siemens PLM:
UG/NX Museum:
Was it "iterative" or "recursive"?
Check out what happens when you do a Google search for "recursion":
"Did you mean: recursion"
bigsmile
http://julianh72.blogspot.com
Yes, I meant 'recursive'. My bad...
John R. Baker, P.E.
Digital Factory
Cypress, CA
Siemens PLM:
UG/NX Museum:
Back to the question; "corrected to plumb" ... Not predicated on the current or past orientations but rather forward looking?
