Edit Material Property
In NX 7.5, I am trying to create some material property. I used "Material Library Manager" to export a single material property. It is a PA6 GF40. I am trying to edit the density to 1.48g/cu cm.
The entry on the xml file is
-<PropertyData property="MassDensity">
<Data format="exponential">1.440000e+003</Data>
I figure this would be a direct replacement of 1.44 to 1.48 but whenever I check the solid body for its density, I get Density (G/Cu Centimeter) = 1480000000.000000000
I am expecting it to show 1.48
What am I doing wrong?
UGNX 8 / 8.5 / 9 - Windows 7 64bit
Productive Design Services
www.productivedesign.com
RE: Edit Material Property
<PropertyData property="Version">
<Data format="string">2011v1Data>
should be
<Data format="string">1.0</Data>
www.nxjournaling.com
