Enthalpy tables for IPA
I'm a mechanical engineer dabbling in some distillation calcs because no-one else is available. The issue is evaporating IPA off a mix with water, and I can find single, nominal values of enthalpy of evaporation for IPA, but not a complete table, like the steam tables. Am I looking for something that doesn't exist? I need to look at various scenarios at different pressures and temperatures.
Thanks for any feedback.
Scott
RE: Enthalpy tables for IPA
I know several chemicals with acronym IPA - isopropyl alcohol, isopropyl acetate, isopropyl acrylate. Which one?
Good luck,
Latexman
Technically, the glass is always full - 1/2 air and 1/2 water.
bah. IPA's?
I prefer darker smoother brews so this particular problem is ill-relevent. 8<)
Sorry, Isopropyl Alcohol.
This time of year, Porter's are nice, but I still like a nice, hoppy IPA.
Thanks. I was looking for pure IPA enthalpy tables, which I could not find, but this looks useful. I'll see if it solves my problem.
That enthalpy diagram has the IPA/water vapor/liquid equilibrium data built into it. See where the curves cross the line y = x (vapor concentration = liquid concentration), that's the azeotrope at the 3 pressures.
Good luck,
Latexman
Thanks you!
