Missing Stress Values in ASME II Part D
I had an enquiry from client where the shell material is requested to be: ASME-SA387 Gr9 Class 2 UNS K90941
This material exists under its own specification in ASME II Part A but no Stress values seem to be shown in ASME II Part D. The only closest thing available as plate is SA387 Gr 91 Class 2 UNS K90901.
There is a little difference in chemical composition between both alloys but why aren't stress values available for Gr.9 Class 2?
What could be the reason?
Many thanks!
Many thanks!
RE: Missing Stress Values in ASME II Part D
If your Code of Construction is ASME Section VIII, Division 1, go to UCS-6 and Table UCS-23. If your material is not listed in the table, then it is not an approved material.
Highly appreciated!
As far as I can tell, UNS K90941 isnt in the 2013 edition of the BPV. However, SA387 is covered in Code Case 2576 and 2630. You might want to review those.
