Problem with Edge Blend
Hi all,
I am currently using NX8.5, i have modeled a small band and need to put a chamfer in the 4 corners, the object is completely symetric but i only seem to be able to blend 2 of the 4 corners. I have attached the model with the two corners done, can anybody give me any advice as to where i am going wrong?
It just constantly brings up an error message shadessad
Thanks in advance
James
RE: Problem with Edge Blend
Good idea, think i will use this approach thanks!
Any idea as to why it didn't want to blend properly?
Thanks again
James
Not a clue!
www.jcb.com
NX 8.5 with TC 8.3
Ah well, least there's a solution!
Thanks bud!
totally weird !
but you should be able to bend that from a flat pattern in sheet metal
I can neither explain why it doesn't create these blends.
But i can show why the first blend ends as it does. (- and require a second blend to look ok.)
This is because the blend doesn't have consistent cap faces to use, in neither end there is no suitable face to use , and there are 2 possible logical options.
Tomas
