Arc Flash Three-Single Phase Multiplier
I've run across a few multipliers in converting single phase arc flash energy to three phase, and vice versa. ARCPRO gives a range of multipliers, the most conservative being three phase energy is equal to 2.2 times single phase. Duke Power suggests that the factor is 2.8.
Any idea where these came from? Is there a reference out there that may explain how they were derived, and why different companies/software vendors will use different factors?
Thanks for the help
Thanks for the help
RE: Arc Flash Three-Single Phase Multiplier
