Creating folded radial dimension in NX9
Has anyone successfully created a folded radius dimension in NX 9
RE: Creating folded radial dimension in NX9
Even in presvous versions it was a bit cumbersome
Are you have problems placing the break in the line?
Yes, I have tried a number of times but just can't seem to make work.
Made a video to show how: http://files.engineering.com/getfile.aspx?folder=b...
You have to be creating a radius dimension (not in inferred mode).
Also you need a point if you don't have one to select for the centre.
Image below from docs, explain that.
Anthony Galante
Senior Support Engineer
NX3 to NX9 with almost every MR (18versions) plus the NX10 Beta
Thank you, that makes a lot more sense.
