Is there an error in NFPA 58 calculation of equivalent SCFM of air regarding PSV relieving rate?
The equation that I see, based on an earlier version of the pamphlet, is:
SCFM (air) = (3.09)(W)[(ZT)/(M)]^0.5
where
SCFM (air) is equivalent air flow
W is relieving capacity of product vapor at relieving conditions in lb/hr
Z is compressibility factor of product vapor at relieving conditions
T is absolute temperature of product vapor at relieving conditions (degrees R)
M is product vapor molecular weight
I suspect - but have not confirmed - that "W" should be in lb/min. Otherwise, my answers are rather disturbing.
Any insight or update or errata note that people can share would be helpful.
where
RE: Is there an error in NFPA 58 calculation of equivalent SCFM of air regarding PSV relieving rate?
From the 2014 NFPA 58
same as in the 08 edition
SCFM (air) = equivalent airflow in standard ft3/min
W = relieving capacity of product vapor at relieving
conditions in lb/hr
Z = compressibility factor product vapor at relieving
conditions
T = absolute temperature of product vapor at
relieving conditions in °R
M = product vapor molecular weight
I recommend you talk to this gentleman. Bruce has been with NPGA for years and authors the NFPA 58 handbook:
Senior Technical Advisor: Bruce Swiecicki, P.E., bswiecicki@npga.org, 21200 S. LaGrange Rd., Suite 353, Frankfort, IL 60423, 815-806-9035
No need to pursue further, the equation of interest is (1) out of date and (2) wrong.
