Mesh density definition
Good morning
I would like to ask you, theoretically, how to you pick a mesh density in one model.What I mean is how do you know how many nodes and elements is right to have in your model..
Thank you..
Thank you..
RE: Mesh density definition
1) start with a mesh that captures the geometry, refine the mesh where you expect stress gradients;
2) refine the mesh again
3) see if the results change significantly
4) if signicant change return to 2), if not exit.
But my question is if there is way to calculate the amount of elements needed without meshing the model first.
