UG NX 8.5 Installation Error
Hi All,
I want to install NX 8.5 on my laptop.
But when I first start installing NX License server It shows error "INVOCATION TARGET EXCEPTION" and it says the application will now exit.
I have a HP Laptop 64-bit and windows 8.1 installed.
Please someone help me in this issue.
RE: UG NX 8.5 Installation Error
Right click on exe for the license service install and select properties.
Select the 'Compatibility' tab.
Check the box 'Run this program in compatibility mode for:'
On the pull down menu, select 'Windows 7'
Select 'OK'
Then run the exe
Anthony Galante
Senior Support Engineer
NX3 to NX9 with almost every MR (18versions) plus the NX10 Beta
