Routing Help Needed for Solidworks 2014 SP03
I was trying to build 2" Pipe Spool Assembly at different locations as mentioned in my
3D Sketch in the Assembly as Attached. But for some reason the elbows are not aligning to the
sketch. Can any one look into this problem and help me in rectifying the problems associated in
creating spool assembly. I have tried creating custom elbows but I had no luck in rectifying the
problem. I am stuck with elbows not creating at 45 deg Bend Angle and at 90 Deg Bend Angle with
171.5 mm Bend Radius. Your help in this issue is appreciated.
Kind Regards,
Farooq
RE: Routing Help Needed for Solidworks 2014 SP03
I only see the sketch, no elbows.
Unless I misunderstand.
Chris, CSWA
SolidWorks 14
SolidWorks Legion
Hi Chris,
I have solved the problem by customizing the elbows and inserting them in
spool assemblies.
Thanks for looking into this problem
Farooq
