110VAC Centre Tapped Earth (CTE)
For a 110VAC CTE system, there's an earth connection between the 2 leads of the output transformer. this splits the 100V out to +55V and -55V. It means the voltage between live and earth is always limited to 55V.
I have a 2P+E socket and i'm wondering if I should connect the earth or not giving that there's one upstream in the transformer. Can someone provide a typical working diagram for CTE terminations please. That'd be helpful.
RE: 110VAC Centre Tapped Earth (CTE)
The earth terminal on a receptacle is used to connect to, and ground metal cases of appliances, tools and equipment connected to the receptacle. The reason is so that any internal fault that may cause a voltage on exposed metal parts of items will have a low impedance path back to the source and provide protection by causing the circuit protective device (fuse or circuit breaker) to open. For this reason the earth terminal should be connected in such a way as to provide a low impedance path back to the supply transformer. The method of connection is subject to local codes. This is an international forum. Post your location and someone local may give more specific guidance.
Bill
"Why not the best?"
Jimmy Carter
Bill,
Thanks for the response. I'm in the UK so BS standard should apply.
Vince,
Absolutely connect the earth at the transformer to the earth sleeve of the 110V socket.
Have a look at http://www.blakley.co.uk/sites/default/files/Trans... - sketch (iv) on page 2 shows the connections relevant to your transformer.
