Best OO implementation?
Hi dear prgrammers,
I would like to know which of the following Implementations of an enxemple-Class is the best one:
Solution 1:
Solution 3: make another class for Book... I would like to avoid it for such a simple data.
What are the pros and cons (Parameters Public and Private)? Why? Is there a solution in between?
Is it important or just a matter of taste? Especially for 'books' (Struct Array) is this question relevant. can we have a Struct Array Parameter Public and unse the native getter & setter on it?
Thand you for sharing your opinion!
Solution 1:
CODE --> matlab
class Library < handle
properties ( Private ) % Here Private !
address = '';
books = struct('name', {}, 'author', {});
end
methods
function obj = Library()
end
function address = GetAddress(obj)
address = obj.address;
end
function SetAddress(obj, address)
% check address ist string
obj.address = address;
end
function AddBooks(obj, names, authors)
% check params (cell arrays of strings)
obj.books = [obj.books, struct('name', names, 'author', authors)];
end
function SetBooks(obj, names, authors)
obj.books = [];
obj.AddBooks(names, authors);
end
function books = GetBooksField(obj, index, field)
% (check field in {'name', 'author'})
books = {obj.books(index).(field)};
end
% Eventuell weitere Get.. und Set... für books
end
end
% Use:
schoolLib = Library();
schoolLib.SetAddress('Mond, 3er Stock');
schoolLib.SetBooks({'a', 'b', 'c'}, {'d', 'e', 'f'});
FirstBookName = schoolLib.GetBooksField(1, 'name'); CODE --> matlab
Solution 2:
properties ( Public ) % Here Public !
address = '';
end
methods
end
function set.address(obj, address)
% check address is string
end
function set.books(obj, books)
% check books is struct array with string fields 'name', 'author'
obj.books = books;
end
end
end
end
% Use:
schoolLib.address = 'Mond, 3er Stock';
schoolLib.books = struct('name', {'a', 'b', 'c'}, 'author', {'d', 'e', 'f'});
FirstBookName = schoolLib.books(1).name;
schoolLib.books(1).name = 'new name'; Solution 3: make another class for Book... I would like to avoid it for such a simple data.
