Automatic Scaling of EXCEL Drawings
I'm using EXCEL 2000. Can you use the built in drawing feature and have objects scaled based on values in cells.
For instance, for a rectangle, you can right click / Format Autoshape / and change the height, width, etc under the Size tab.
But to set those equal to a cell value in VBA, I can't find the rectangle's object name (i.e. rectanglename.Width = value of cell)
Many Thanks,
alan54
Many Thanks,
alan54
RE: Automatic Scaling of EXCEL Drawings
2nd question: try the selection.
with regards to a scaling factor, please note the code below used to change an object's size. instead of the textbox1.value, change code for a cell input. the code below is not in its entirity as i appreviated what the sub is actually used for. be certain to have object selected.
Private sub CommandButton2_Click()
on error goto no_selection
wid=selection.width
hei=selection.height
sf=1+textbox1.value/100' change to sf=range("sf").value or ?
selection.height=sf*hei
selection.width=sf*wid
exit sub
no_selection:
end sub
interesting, but ...
-pmover
ActiveSheet.Shapes("Rectangle 1").Height
You can read/write all relevant properties in this manner, so in your case ActiveSheet.Shapes("Rectangle 1").width = Activesheet.Range("A1").Value
The width/height etc. are specified in points = 1/72 inch.
Joerd
