stress, in the capsule diaphragm
if you saw a convoluted capsule diaphragm, you may wonder how to calculate the stress. I do not know. help me?
stress, in the capsule diaphragmstress, in the capsule diaphragm(OP)
Red Flag SubmittedThank you for helping keep Eng-Tips Forums free from inappropriate posts. Reply To This ThreadPosting in the Eng-Tips forums is a member-only feature.Click Here to join Eng-Tips and talk with other members! |
ResourcesThe world has changed considerably since the 1980s, when CAD first started displacing drafting tables. Download Now
Prototyping has always been a critical part of product development. Download Now
As the cloud is increasingly adopted for product development, questions remain as to just how cloud software tools compare to on-premise solutions. Download Now
Engineering-centric businesses face a number of challenges today, but unmanageable design and change processes don’t need to be counted among them. Download Now
RE: stress, in the capsule diaphragm
I am at a loss to understand Your question. I work with aerospace pneumatic and fluid system components and have never heard of a "convoluted capsule diaphragm"!?!?
Photos/sketch of the component MIGHT help us understand what it is.
Regards, Wil Taylor
Trust Me! I'm an engineer!
Trust - But Verify!
We believe to be true what we prefer to be true.
For those who believe, no proof is required; for those who cannot believe, no proof is possible.
Unfortunately, in science what You 'believe' is irrelevant û "Orion"
thanks.
Or a diaphragm pump?
Does the cavity that the diaphragm moves in have a function other than being the surface the diaphragm rests against?
I suspect you're looking for the load or pressure that causes it to invert. Can a test be done?
STF
also, it "is" also a diaphragm pump, when the diaphragm is pushed down (as a ground check when installed on fire extinguisher).
i am looking for the cycle life when the diaphragm is pushed down (and let it up) when a constant pressure is applied.
thanks.
Anything more profound than that, and you may need to go down to the basics: Timoshenko et. al.
One thing that might help, since the disk is circular, is that you can assume the stress in any "dr" ring is uniform, so it's a one-dimensional integral.
STF
Based simply on what your sketch shows, I don't see how the applied upward pressure force and the axial travel of the piston will overstress the metal diaphragm. The piston and thin metal diaphragm will simply unload once they contact the upper housing surface. However, if pressure is applied to the thin metal diaphragm to drive the piston downward, then you need to look at the stresses in the weld joint between the thin diaphragm edge and the thicker piston edge. This is where it will likely fail when the piston stops against the lower housing surface.
(i have no access to FEA.)
ps, the diaphragm is not welded to the stop/piston.
