Print all open drawings to PDF
While searching for a user requested solution, discovered this journal:
http://www.nxjournaling.com/content/print-all-open...
This has been very helpful, but not quite what we need. Is anyone aware if there is a similar journal that would create a PDF of all open drawings? I attempted to set my default printer to PDF, however I was prompted to enter each name manually. It would be nice if the PDF files were named by "Descriptive Part Name"... and multi sheet if applicable. (Using NX8.5.3 in native mode)
Thanks.
