Automatically generated parts?
I have a large number of similar parts to generate. They are all identical except for one dimension.
The data for the dimension in question is generated elsewhere but isn't that complicated, just a few lines of code really.
I know that its possible to record macros in SolidWorks & have recorded one but my object orientated programing skills are naive but not missing completely.
I like to set SW up so that I can generate the parts & dimensions automatically rather than one at a time.
Is this possible?
Nic
Is this possible?
Nic
RE: Automatically generated parts?
Eric
Is there a way of automatically saving the individual instances separately with out the attached design table?
Yes. A DT created in the assy can be used to control the configuration displayed for each instance of a part.
