120 mhz bandpass filter
I'm working in a 120 mhz bandpass filter, i've designed it through a high-pass after a low-pass filter.The problem is that although i`ve simulated it with and without the pads and microstrip lines, whenever i make the PCB, i never obtain the desired results.I`ve tried to imulate it with RFSIM99, LIBRA and MICROWAVE-OFFICEE.The specification for my filter are:
BW1dB=14 MHz
BW3dB=16 MHz
bandpass s21>-2dB
I'm using SMD lumped elements on a miscrostrip structure PCB.
Can anybody help my?any idea?what am i doing wrong?What can i do to obtain more or less the same resaults as in the simulations?
Thanks in advance
BW1dB=14 MHz
BW3dB=16 MHz
bandpass s21>-2dB
Thanks in advance
RE: 120 mhz bandpass filter
Analysing of microstrip structure in software like LIBRA or others has always a little error connetcted to the analytical model of analysed structer.
To have more accurate results You should use some 2.5D simulators like MOMENTUM, SONNET etc. And also You have to remember about very detailed and accurate defining of dielectric material. In most cases it is the reson of all errors. Good luck.
We used Touchstone for analysis, results were pretty close to the Touchstone outputs.
kch
PS:biff44 is correct, do an actual bandpass design, fewer parts and better results.
Hipass-Lowpass approach is used when you have a very broadband or steep rejection on both skirts of the filter.
For the spec that is given, your approach is correct. If you use a bandpass design, then the ratio between L&C in series will be very hard to realize (e.g. 1pf/1000nH).
Use Lowpass & hipass with one finite transmission zero (finite pole) on each side of the BPF will solve the problem.
Krytar
