injection molded part question
I am designing an injection molded part that has a couple tricky areas. All the areas shown in green below can have no draft. All the other surfaces can have 2 degrees or more. Currently I am envision the mold opening and closing as the two arrows indicate in the first isometric view. The second isometric view shows the trickiest area, a slot that is only .06" tall and 1.25" deep and 1.6" long. My question is whether this slot can be made with zero draft with just the open-close mold or whether a side action is needed to reduce the length of the cantilevered thin piece in the mold. Is this slot going to be a problem area in the mold no matter how I do it?
RE: injection molded part question
Paul Kuklych
http://www.improve-your-injection-molding.com
Paul Kuklych
Just my two pence worth..
H
www.tynevalleyplastics.co.uk
It's ok to soar like an eagle, but weasels don't get sucked into jet engines.
I think either way will be problematic. The shut-off from the side will probably not happen as the blade will flex. The usual "rule of thumb" is thin blades/cores should be only 3x to 5x (max) thickness or diameter for reliability.
Could you have the slot much thicker (e.g. .25", tapered to the tip with say, a series of internal ribs to give the .06" between the tops of them?
Incidentally, unless this is to moulded from a zero shrinkage material, the slot will close up and be zero gap on the outer edge. Right angles are notoriously difficult and usually the tool is made so it can be adjusted after sampling to give the required 90 deg.
Have you considered making it in two parts, split along the slot and affixing together by some means?
H
