Frost depth consideration in case of refusals
Dear all,
In case of foundation design, steel pile and concrete pier embedment is kept larger than frost depth.
How does one approach a situation where refusal is encountered, even before frost depth is reached.
Is it fine to keep foundation at lesser depth than frost till it is fine in uplift and lateral deflection. (In case of refusals)
Avdhesh
Avdhesh
RE: Frost depth consideration in case of refusals
I have same question further as jayrod12, "what about frost heave from adfreezing grabbing the sides of the pile and popping it out of the ground. I'd be inclined to be more worried about it."
Thank you for your prompt response.
Avdhesh
Avdhesh
When I am working on a problem, I never think about beauty but when I have finished, if the solution is not beautiful, I know it is wrong.
-R. Buckminster Fuller
Thank you
Avdhesh
Since the depth of freezing, depends on water content, all other conditions the same, where is the shallowest depth of freezing "Frost Depth"?
Answer: a lake.
Be careful throwing around "standard" terms.
