Hiding blocks
Hiding blocks
Hiding blocks
I`m using draftsight version V1R5.2 and i need to hide some blocks, is this possible?
I create a set of blocks which i then insert into a design but i would like to check if they have been inserted into the correct place as i`m using a script. Is it possible to say turn off blocks A, C & D and leave B & E visible?
Any help is welcome.
RE: Hiding blocks
Can you place them on different Layers and then turn those layers off or on as your design dictates?
Sylvia
