FACE TO FACE LENGTH OF BRONZE GATE VALVE
DEAR FRIENDS,
BELOW IS THE SPECS OF BRONZE GATE VALVE WHICH MENTIONS F TO F LENGTH AS 152 MM, BUT MY MANUFACTURER IS SAYING F TO F OF 152 MM IS WRONG & IT SHOULD BE 81±1.5 MM AS PER THEIR STANDARD. WHEN WE INFORMED OUR CLIENT, HE WANT F TO F LENGTH AS PER THEIR SPECS ONLY. CAN ANY ONE HELP ME ON THIS. WE CANNOT CHANGE THE MANUFACTURER AS OUR CLIENT IS INSISTING ON THAT MANUFACTURER.
VALVE, GATE, ANSI CLASS 150, FLAT FACE,FLANGED, UNION BONNET, SOLID WEDGE, 225 PSI,WATER OIL & GAS (W.O.G) AT 150 DEG. F., BODY MATERIAL COPPER ALLOY TO ASTM B-62, ALLOY NO. C83600./ BS 1400 LG2, TRIM MONEL, SIZE IN INCHES: 3/4 - LENGTH, F TO F: 152 MM
RE: FACE TO FACE LENGTH OF BRONZE GATE VALVE
B16.10 has 152 being a Y globe or Y check valve at 3/4" #150 or a #300 3/4" gate valve is 152.
However it lists a 3/4" #150 gate valves as 117mm, therefore the 81mm looks like it is a different code.
You could therefore specify a #300 valve drilled to # 150 flange dimensions?? Given that bronze may be de-rated compared to steel, to meet your pressure requirements you could easily have a #300 valve here, but drilled to #150
Alternatively: ask if pipeline can be changed, or if the supply of short valves can be accepted with fabricated 'spool pieces' or fabricated or standard mounting pieces between the valves and pipeline.
