Moment Capacity Near Point of Lateral Bracing
Hello, I have a question that I cannot find the correct answer to online and which has stumped one of my coworkers.
I have a beam approx. 45' long, pinned on the ends with a column about 32' from one end (so a continuous span). After applying the loads the greatest negative moment occurs at the column. The moment is negative for about another 13' from the column in the 32' span. When I calculate my moment capacity it is greatly reduced because I have a 32' span when the compression flange (bottom of beam) is unbraced. Cb=1.4 which helps slightly but according to code that beam will fail due to LTB 1 unit away from the column. I can't imagine that beam would buckle so close to the point of lateral support.
anyone else run into this before?
Thank you,
Steve H. E.I.T.
RE: Moment Capacity Near Point of Lateral Bracing
Quote (OP)
LTB will occur over the entire 32' unbraced length of beam. It isn't a phenomenon that occurs just at a discrete point. If LTB occurs, your maximum bottom flange lateral displacement will still probably occur in the middle third of that 32' span.
The greatest trick that bond stress ever pulled was convincing the world it didn't exist.
