Bore Casing Design
Bore Casing Design
I have a project that has a bore under an irrigation ditch. The original design had a 54" steel casing pipe for a 36" carrier pipe. The casing pipe was specified to have a minimum thickness of 3/4". Due to the amount of construction activity happening these days, the cost and availability of the steel has made the original spec almost infeasible. The casing under the ditch will only have about 4' of cover to the bottom of the flowline, so I don't see an issue with a smaller casing thickness during winter. In the summer, however, the ditch runs full and will have the added pressure from the water. Does anyone know where I might find a chart that shows the minimum casing thicknesses that can be allowed for certain pressures?
Thank you,
Thank you,
RE: Bore Casing Design
http://www.sdwas.com/Documents/Vol2/Section2/Divis...
