Results file cannot be found
After completing optimization process in Abaqus/CAE I got an error when trying to open results.
"The results WORK_DIRECTORY\Opt-Process-1\TOSCA.OUT\Opt-process-1-Job_post.odb cannot be found. Do you want to combine the optimization results?"
-->YES
"Warning: Required optimization result directory WORK_DIRECTORY\('Opt-Process-1','Model-1','Task-1','Completed','6') not found."
There is no folder "Opt-Process-1\TOSCA.OUT\" generated, there is just a .out file "Opt-Process-1\TOSCA.OUT". Optimization process finished without any errors and Abaqus/CAE was running with admin rights.
Any thoughts, what went wrong?
-->YES
RE: Results file cannot be found
The correct path is:
"The results WORK_DIRECTORY\Opt-Process-1\TOSCA_POST\Opt-process-1-Job_post.odb cannot be found. Do you want to combine the optimization results?"
I have noticed that folder TOSCA_POST is created in the initial cycles of the analysis, no files are generated in it during analysis and is then removed when analysis finises.
Any comments?
