Liquid carryover in production separator
We are facing a problem with liquid carryover with gas. The separator is equipped with van type demister pad but gas outlet nozzle have demister. Gas outlet nozzle looks behaving like siphon. Separator is operating at 75psig and had flow rate is 4.5 MMSCFD. Gas valve is abot 25% open. Please any suggestion how to stop carryover problem.
10815L
10815L
RE: Liquid carryover in production separator
Carryover is usually caused by too much gas flow. Have you check the vessel sizing against standard methods?
David Simpson, PE
MuleShoe Engineering
In questions of science, the authority of a thousand is not worth the humble reasoning of a single individual. —Galileo Galilei, Italian Physicist
I had prepared the attached spreadsheet for separator sizing. Perhaps this could be one of the ways to check the size of your separator for its adequacy.
Regards.
Ajay S. Satpute
Regards.
Ajay S. Satpute
(PS. Reposted)
the known is issue is small piping and control valve but this separator is sized for 21 MMSCFD gas, for more details please find attached P&ID.
10815L
sorry, additional information, Flare gas PCV is adequate while PCV for Plant side is inadequate. carry over noticed both cases but quantity of liquid carryover is very high when gas open to plant because of PCV wide opening.
10815L
Here is Design Parameters; 50000BOPD, 50000BWPD and 21MMSCFD gas, MW 27, DP 150 psig and DT 200 0F
Operating parameters; 15000BOPD,21500BWPD and 4.5 MMSCFD. operating pressure 70-75 psig and temp 130 0F.
To me problem in demister pad orientation because this separator have vertical demister pad and gas outlet nozzle is without demister pad.
10815L
Sectional drawing of the separator with liquid levels would help / essential to see what it is you're talking about.
What sort of incoming flow steady or slugging?
What is level control like - good or varies a lot
What was design intent of the vessel in terms of liquid in gas?
Has anything changed?
Give us some data and we might come up with more than general comments. We've got about 10% of what we need at the moment
significant amount of crude and water is coming in gas outlet stream, for first two minute continuous spray and then like mist.
incoming flow is smooth and continuous, i haven't seen any sign of slug flow.
levels are being controlled very good. The design intention to separate all three phase with maximum 0.1g/MMSCFD.
LittleInch, is it demister pad or PCV problem, as i noticed PCV is wide opening even gas flow is 3-4 MMSCFD.
10815L
