How to supply voltage to a circuit board that needs +6.5V AND -7.5V ?
Hello!
I have a test board for a maroc3 asic and it must be supplied with +6.5 Volts and 380mAmps AND -7.5Volts and 40mAmps maximum current.
I have two one-channel voltage/power supplies(PS), (+,-, ground) from different manufacturers.
If I connected the two PSs in series, as I have drawn in the attached picture, then connected the positive(Red)of the second PS to the +6.5V input of the board, the negative(Green) of the +7.5V PS to the -7.5V terminal and the wire connecting +(+7.5) to -(+6.5) to the board's ground(Black), would that be correct?
And, if I take the ground from the wire connecting the two, are they still in series or the connection becomes parallel between two voltage supplies?
If it has become parallel, and the 6.5V and 380mA should act as a voltage supply and the 7.5V and 40mA is a current supply , it should be ok, right? because the Voltage of the voltage supply is smaller than the voltage of the current supply and the current of the current supply is smaller that that of the voltage supply.
Please advise me on how to supply this board with both -7.5V and +6.5V using two different PSs: I have seen this done with +12V and -12V but the quantities are identical and, if I have 7.5V and 6.5V , is it still alright or will that cause problems and if so, what might those be?
Thank you for your time and please help me!
PS: we will also buy a new power supply with 2 channels; what specifications should that have in order to properly power this board?
Thank you!
Thank you!
RE: How to supply voltage to a circuit board that needs +6.5V AND -7.5V ?
The specifcation is impossible to predict - but you need to consider regulation, noise, ripple, surge capacity and numerous other things when making the choice.
In that configuration, are the two power supplies still in series or is it now parallel ?
Of course, if you only look at the two power supplies, they are in series. And that doesn't change if you connect load to them the way you show.
Is it important for you what you call the connection?
Gunnar Englund
www.gke.org
Thank you for your reply!
What it is called is of no importance but how it might behave is (connecting in parallel two voltage supplies of different values) . I am trying to understand and predict what could happen tomorrow when I make this setup.
I will just leave it like that, without load for a few minutes and then connect a simple resistance and watch what happens to the current (how much is being drawn).
Gunnar Englund
www.gke.org
Benta.
What about using Negative and Positive adjustable voltage regulators to the +/-12 PS
Look at the following links
http://www.ti.com/lit/ds/symlink/lm137.pdf
http://www.ti.com/lit/ds/symlink/lm117.pdf
Good Thinking = Top Results :any comment - daveross100atgmaildatcom
