Forensic Geotechnical Testing to Verify Proper Compaction
Are there geotechnical tests that can be performed to confirm whether or not soil was properly compacted fifteen years ago? If so, I'd very much like to hear about those tests.
The greatest trick that bond stress ever pulled was convincing the world it didn't exist.
RE: Forensic Geotechnical Testing to Verify Proper Compaction
Changes in compaction with time are minimal unless you have continuous vibration nearby, reactive materials or materials susceptible to shrink/swell.
Changes in moisture content do not change the compaction percentage since calcs are based on dry unit weight. Moisture content will affect reactive soils and soils susceptible to shrink/swell.
There have been some who would suggest the use of dynamic cone penetration tests - it could tell you the uniformity of the compaction - even the miniature ones if the soil is not gravelly. (http://researchspace.csir.co.za/dspace/bitstream/1...) - this is for pavement design, but again, it shows consistency. As an example - I have a few other references but don't have time at the present to look (shopping in Kuala Terengganu beacons!) Cheers
I'd jam a dilatometer in the ground and get a profile of the fill materials showing the various geotechnical parameters wiwth depth. I'd also do a boring or several, get tube samples and perform some lab testing.
I'm just not sure how you'd benefit by knowing whether this 15 year old fill exists at 94 or 99 percent compaction.
Do tell. . .
f-d
ípapß gordo ainÆt no madre flaca!
1) Most soil types will become more compacted with time.
2) If compaction is insufficient at present, that suggests that compaction was insufficient to begin with.
Is that logic flawed? I admit it: I'm a dirt-tard. If I understood correctly, this is what my local Geo-guru told me last week.
