Desalination project Issue
I am working on desalination project. I made a small prototype for desalinate 0.5 gpm but this need to be constructed for 200 gpm.
In our prototype I bring process water (saline water) to bottom part of an auger (please see attached picture) and I cool down the water in bottom part of auger by a cooling coil feed by a 5 ton chiller to around 40 ͦF . When the temperature drops to 50 ͦF salt start to crystallization and with auger I remove the salt from water and pure water over flow from a half pipe we provide for this purpose. (Please see attached picture).
The issue I am having is this: When salt start to crystallization it attaches to cooling coil copper piping and get hard and harder and each 5 to 10 minute we have to stop the process and remove the salt from cooling coils and start over. I appreciate for any input.
I need to add that, before using this system I tried to run the salty water through shell and tube heat exchanger but salt crystals was plugging the heat exchanger.
RE: Desalination project Issue
It seems to me like you are taking too big a temperature drop in a single step. Have you considered doing it in 2-3 stages?
David Simpson, PE
MuleShoe Engineering
In questions of science, the authority of a thousand is not worth the humble reasoning of a single individual. —Galileo Galilei, Italian Physicist
Zdas04,
Doesn't mater for desalination we need to go to that low temperature and it will cause the issue.
Doesn't matter? At 40F you are way super saturated. At 60F you are less super saturated. If you can get the solids to precipitate in a sequence of smaller steps you can sometimes keep them more or less where you want them.
David Simpson, PE
I'd think you could coat the auger and/or cooling coils with (for instance) a Teflon spray coating, to help it shed adhered salt crystals more easily. Short of that, some method of backflusing/washing the surfaces with warmer or desalinated water on a periodic basis will need to be contemplated. Like descaling a boiler, make it a required periodic maintenance item.
