Flare Tip Material - 310 S
Do we need PWHT for flare tip material 310S ?
Also I check in B31.3 which gives for P-8 (310S group), PWHT requirement for all thickness but does not indicate the Temperature and the holding time as indicated for other materials.
Please advise.
RE: Flare Tip Material - 310 S
B31.3 Table 331.1.1 indicates no PWHT required for this material.
If the flare tips were cold formed, you may want to re-think a thermal treatment.
I examined a flare tip last year that had crumbled for reasons that included severe sigmatization. We went with Inconel 625 on the replacement.
I think you need to define what part of the flare tip, since they have a number of components.
"If you don't have time to do the job right the first time, when are you going to find time to repair it?"
