The Next Step
The Next Step
Straight out of high school I did not exactly know what I wanted to do, I just knew it was going to be something I got to use my hands as much as my brains. I found a two year automated manufacturing program at the local tech school that I have recently completed. Now I have found out that it would have been better for me to get a bachelors in Manufacturing Engineering. I do not have the time to go back and start the engineering program. What I can do is transfer my credits to an online 4 year Manufacturing Management program or take night classes and get a 2 year Mechanical Design degree. Knowledge wise I feel that Mechanical design would get me closer to a Manufacturing Engineer type job that I want. Career wise the Bachelors in Management sounds better on paper just for the simple fact I would actually have a bachelors degree in something. I was hoping to get some feedback on the subject from engineers that are out in the field and know what employers are looking for.
Thank You
Thank You
RE: The Next Step
an Engineering degree would be needed to work in an Engineering office; but don't rule out mechanic.
most colleges are associated with a university (usually in the same neighbourhood) and should give credit for your courses, 100% credit is another question; consider the higher expectations of university work, I guess the most I`d hope for would be about 80%, maybe only 50% (ie 1 year credit for your 2 years worked). but it depends on the school ... talk to them.
don`t rule out having a trade. Possibly the best would be to start somewhere as a mechanic, work night school (sponsored?), and more "up" to the engineering office.
GL
RE: The Next Step
RE: The Next Step
RE: The Next Step
RE: The Next Step
Frankly my bias would be towards the Mechanical Design degree, IF it is ABET eligible.
If it isn't then you are paying a lot of money and time for an interesting, but not especially recognised, piece of paper. The learning in its own right may be worthwhile to you.
As you get older your work history will be far more important than what qualifications you have, for most engineering type jobs.
Cheers
Greg Locock
RE: The Next Step
My guess is a BS/BEng (depending on location etc.) in any vaguely relevant engineering will be adequate for the typical Manufacturing Engineer job.
What is Engineering anyway: FAQ1088-1484: In layman terms, what is "engineering"?
RE: The Next Step
knowledge is power
RE: The Next Step
knowledge is power
RE: The Next Step
One of the hardest but better than most of the other options you mentioned.
RE: The Next Step
